Hey everyone, in the process of building a 40x16 pool, with built-in hot-tub and shelf. We are in northern california with a lot of tree cover, so will have an automatic cover over the pool and have it closed at all times when not in use. This is my second pool, we built a pool in our old house and had all equipment which I was not a fan of. So instead of jumping on whatever the builder suggests this time I'm coming here to ask for some advice.
here is what the contractor is suggesting:
2x Pentair Initelliflo VS 3HP pumps, 1 for pool/spa, other for spa & bubblers
1x Pentair Intelliflo 2.7HP waterfall pump
1.5 HP blower for spa jets (brand not specified)
Jandy JXI 400k btu heater with Versaflow Bypass
Jandy Clean and Clear plus 420 cartridge filter
Jandy iAqualink Pool/Spa control
Bootstrite sweep booster pump
Polaris 380 sweep
Jandy LED lights
AutoFill pool water
Auto Tablet Chlorinator
One thing that immediately jumps out at me is the mix of Pentair and Jandy equipment, is this advisable? Also, using Jandy for automation, is that a problem with Pentair pumps?
For sanitation, In-line chlorinator sounds OK, but wondering if I need to do UV as well since the pool cover will remain closed 99% of the time? Also, wondering if I should explore SWG, but assumed that would cause issues with the built-in automatic cover.
I've heard good things about cleaning robots, should we look at those versus the Polaris, or is a supplement to the standard sweeper.
Any other critiques on the equipment or suggestions?
Thanks for your help!
Polaris 380 sweep
Jandy LED lights
AutoFill pool water
