New Build in New Braunfels, TX. Construction began 9/27/19.
kimkats
44,869
Tallahassee, FL
My light switch is in the pool house right by the pool. It is by the steps leading to the pool.
What a wonderful sound that had to be............hearing the trucks drive up!! It is time for your own set of links!
The first set is about how to get a good plaster job. The second set is about how to care for you pool:
Plaster links:
Ten Guidelines for Quality Pool Plaster Best one of all
All Plaster Finishes Should Last 20 Years
Not All Color Pigments are Good for Pools How to pick a good color for plaster.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
Trouble Free Pool
Now is also a good time to ask your PB what test kit they provide. Let us know so we can fill in an holes.
Kim:kim:
shonda_gonzalez
79
New Braunfels, Texas
Plaster links:
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
Trouble Free Pool
Kim:kim:
Thanks Kim! I had a work meeting this morning and missed most of it, but it was definitely a site!
DB-Cooper
200
Austin, TX
Our builder actually said the same thing about a robot cleaner. You are right about salt water, no builder we talked to would consider it and if they did, they'd void all warranties with the pool. Thanks for the suggestion and the link!
I think they all say that. Proof is in the pudding when you tell them, “I will only buy salt and expect warranty on everything except perhaps decking”. You’d be surprised how many become unallergic to salt.
shonda_gonzalez
79
Ready for more concrete! We added some steps and a landing to the design yesterday. The original plan was for the patio to extend the length of the house with a six inch step down. It doesn't look like they formed it that way and it's made me question whether or not to have them make the correction. We plan to add an exterior door off the master for our next project. Thoughts?
RMcGirr83
642
Tuscola, TX
kimkats
44,869
Tallahassee, FL
There should be "chairs" under all of the steel. They are little things that lift up the steel so it is in the middle of the concrete.
How??will they stop the concrete from going into the pool?????
How high is the forms? That is how high the concrete could be.
I would NOT allow them to do anything else until you have a meeting with the PB and formers.
shonda_gonzalez
79
The coping is cantilevered concrete, so they are pouring the coping with the decking. I think that tile is going in next, then the coping and decking, so they likely still have some work to do, but my husband is contacting the PB today to discuss. They definitely didn't frame it per plan.
shonda_gonzalez
79
There should probably be a sand base under that re-bar for the deck
Thanks. We're discussing with PB today and I'll bring this up. I probably posted pics before they were done with this portion of the job. My biggest compliant of this build is knowing what they are doing when. Even when we get a schedule from the PB, crews show up early and work is done before we know it.
