Hello Everyone,
I need some assistance with my pool plumbing. The original installer of this pool placed the filter way too close to the fence, it's literally up against it and it's very difficult for me to do any maintenance. I want to remove and reposition my Jandy valve so that it faces the opposite direction. This would place the pool pump and filter away from the fence. My question is about how I should do this – the return lines appear to be cemented to the Jandy valve, so I believe I’ll need to use a hacksaw to cut the return lines and then add some new pipe and a new Jandy valve . Is this the correct approach ? or is there other methods for removing this valve? Unfortunately, if I do cut the return lines to remove the valve, I will not have a lot of pipe to play with.
I’m attaching a few pictures to illustrate my situation. I would appreciate any suggestions or thoughts on better methods to accomplish this.
Thank you in advance !
