hello,
need your urgent advice.
I have a complete pentair solution, easy touch, intellifo, chlorinator, etc. and do have the following problem:
-> main Filter pump doesnt start.
I checked the following:
a) replaced the power relays. thought it might be that, since I dont hear this 'click' sound once the relay is activated, like on all the other relays.....no change
b) also swapped the power cables from circuit board FLTR Pump to AUX1.....no change
c) connected 220V power supply, directly at the main pump and it works... but then of course I can't control it
=>> so the pump and relays are ok, it just doesn't get the ON command, even in time out or service mode, I cant switch it on, local pump panel is also off.
Running out of ideas, can you please ADVISE of a possible root cause and solution. what ON commands are required? wlo filter pump ON, the chlorinator doesn't work, the heater, PH measurement, dosing, etc.
I am running currently on the secondary pump normally used for vacuuming.
attached a picture, there are many cables connected to the Main pump relay but as you can see it is rather chaotic....(note: bought the house with the pool and have no further details.)
