I did a Pentair conversion w/ 522046 back in Oct 22 to upgrade from Easytouch to Intellicenter. All has gone well and pretty happy with system.
Came back from out of town yesterday and noticed pool cleaner running when it shouldn’t. The pool main pump is running fine on its schedule, just not the booster - comes on when the main pump comes on. Working fine until now. Found when I cycle main pool pump the Pentair booster pump cleaner also comes on and off with main pump. I removed power leads for the booster pump from its relay in the Intellicenter So not to overheat the booster pump until I figure this out. Wondering if this sounds like the Intellicenter booster pump relay, or main pump relay is bad? Both relays click when actuated for their intended use. I swapped out the Booster relay with an unused relay in original booster relay location, and had same problem. Any ideas?
