Hello everyone,
My filter pump won’t turn on as scheduled or through the ScreenLogic app. My pool cleaner and all other functions work fine on schedule and through the app. It’s just the filter pump. The salt generator also comes on at the scheduled filter pump time. It’s just the filter pump that is off. I also have “Display Not Active” on the filter pump as I’m in Auto mode.
I can turn it on in service mode.
I’ve read a few threads but couldn’t figure out the issue. I was also helped by Jim to wire the pump directly to power and not through the relays which solved my power out failures.
This new problem was intermittent but since the last time I had the pool company over (and I deleted and reinstalled the schedule), the pump hasn’t been on the last two days. The pool company also had pentair go in and review everything from their side. There were no conflicting schedules etc.
Also, a month ago when the pool company was over, they said the comms wire was barely attached to the board. The reattached it. Pool company wants to now replace the board on the Intellicenter, which is $1400. Before I spend that sort of cash, I thought I’d get a second opinion here.
My setup is as follows:
- Pentair Easy Touch Control System
- Pentair Intelliflow Variable Speed Pump
- Pentair Intellichlor Salt Chlorine Generator
I am adding screenshot of the pump tab on the ScreenLogic app. I turned it on in Service mode this morning. Also a pic of the circuit board, in case that helps.
Aux 1 in the schedule pic is the pool cleaner
