How much liquid chlorine do you add per day? I’m in DFW area with about a 20k gallon pebble tech pool. The pool is mostly in direct sun but it gets a good amount of shade starting around 3 pm this time of year. I have been using tabs and watching my CYA closely, it is now at 40-50 so I’m switching to LC. All my tests are in the recommend ranges in the Pool Match app - I could actually boost my calcium a little bit.
Now that I’m doing the TFP method I’ve measured my OCLT (all is good) and measured over the last few days my daily chlorine usage. My testing has shown that I’m losing about 2 ppm of chlorine per day. From reading here it looks like this is about average so here are my questions:
1. Are y’all really adding almost a gallon of LC every couple days? This seems really exorbitant. Lots of people I’ve talked with test once a week and “shock” once a week as well. They might add some extra after a swim party.
2. I plan on testing FC every couple of days to ensure my levels don’t drop below the minimum. Does that sound about right?
3. The TFP method doesn’t take into account phosphates or TDS. I get lots of leaf debris and now pollen tubes from the lovely live oaks that are around. Should I pay more attention to this than the “normal” pool owner? I’m literally having to sometimes clean both skimmers out 2x a day due to all the debris.
4. I’m running my pump about 10 hours a day at low RPM’s. Any thoughts about adjusting that up or down?
I appreciate this forum and have learned a lot. Thanks in advance for your time and your replies.
