It will make it last longer, yes....BUT....think of your FC throughout the day, it will be burning off all day with sun exposure slowly lowering. With the higher CYA the point where the chlorine stops working will be higher. So...let's say you go from 50 to 60 on CYA. Now your chlorine will go down 6ppm over 14 hours of sun exposure instead of 12. Problem is, now your chlorine level needs to stay above 7 instead of 6 to be effective. You may have gained a couple hours of 'life' but you're still using the gallon a day to keep the level a bit higher. Hope that makes sense. I agree with
@Darin, save yourself a headache (high CYA) and get a SWG.
Here's the chart for ref
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.
www.troublefreepool.com
