Ledge Lounger Help
jtburf
486
Houston, TX
Local member has them, I asked your exact questions.
Here is what he told me
I would say it depends. Its not my chill out chair, I usually lay down in a Chaise with cushion and under the shade. Here in Houston, straight laying out meh. My issue is there not comfortable but look awesome. I wish I got grey.
I prob spent less than 2 hours last season it. I have awesome chaises from Restoration Hardware just cant leave them.
It a personal decision. White 1/2 seconds can be had here locally by the way but again doing over I would not get white and pay more
Arcturusdrive
11
NC
Very personal decision, indeed. We bought 2 and enjoy them greatly. As much $ as we're spending on the pool, landscaping, etc., it made sense for us given the visibility of our deck. That said, to each their own.
(I will say that we did much better buying their "seconds" -- each was in the $450 range that way. Requires a phone call to check their inventory).
tampatommy
258
Tampa, FL
Do your ledge loungers float at all, even when filled with water? Or are they firmly planted to the shelf. We have the tropitone knock offs and just the water moving from people jumping in the pool causes them to shift on the shelf if nobody is sitting in it
jscottou22
16
Lantana, TX
I just purchased a couple of the SwimWays Sonoma Chaise Lounge chairs to serve as our ledge loungers. They are hard plastic, floating loungers, but if you drill a few holes in the bottom, you can fill them with water so they stay in place on the ledge. They were only about $125 ea., and so far they have worked well. Much cheaper option.
Reactions: Pool_rookie8
Arcturusdrive
11
NC
Our loungers sit flat and don't move.
poolnoobgrandma
483
Seminole, FL
We went with Adirondack chairs from Lowe's for the sun shelf.. allows us to sit and enjoy when we don't want to get into our suits and get all wet. I'm shopping for in-pool loungers now.
Edit - I have been on cruises where they have the fancy ledge loungers. Getting in and out .. well, graceful isn't the term that comes to mind... :rolleyes:
Reactions: toxdocar
DaveHidalgo
12
New Orleans, LA
We have deeper than normal water depth(16") on our new sunshelf and that really stifled the options for finding suitable in pool chairs. Most all of the cheap options would float away or sink to the bottom of the pool.
Fortunately, we found that there were Risers / adapters now available online that fit beneath some of the Ledge Lounger chaises that elevated them so we could use them. We got a pair of the Deep Chaise they have and with the risers underneath them they are sitting up nicely on the deep shelf and not floating or moving from where we put them. Yes, the chaises are a plastic material and won't compare comfort wise to a lush cushioned chaise like was mentioned from Restoration Hardware. These did have a cushion option but I recall that it's not meant to be in the water where we keep our chaises. Instead we added their headrest pillows to the chaise so we would have something comfy to hold our heads up while we read or ipad in the pool.
Reactions: Love2Fly
Amazed
103
San Antonio, TX
I am about to bite the bullet and buy a pair. I think I want the teal color. I went to a local store and they had some color samples but did not have teal. Has anyone seen ledgers in this color?
bmoreswim
Platinum Supporter
6,515
Central MD
COSTAalotRONDACK chairs. But seriously, if they work well, the cost is not as important for me. I love that teal color. Though I don't have a ledge, it will be good to hear someone test them out.
So am I correct that they fill with water through the 3/8" holes in each leg and then it drains out when you remove them?
Reactions: DaveHidalgo
poolnoobgrandma
483
Seminole, FL
I love our Lowe's blue adirondack chairs. I like that they are lightweight so we can easily move them around. They don't have built in drink holders, but the arms are 100% level, so you can sit a drink on either (wide) arm. Or I could get my handy husband to drill holes and add a cup holder. And most of all, I love that they are DONTCOSTalotRONDACK chairs. Got them on sale for under $16 each.
Reactions: Snikwah
MeowMeow724
296
FL
These don't float around? I didn't think they would stay in place. We have these in a different color and I am driving myself crazy trying to find something that works.
Sams Club has polywood adirondacks with marine grade stainless hardware for $200 each; I was just considering those!
poolnoobgrandma
483
Seminole, FL
They (Lowe's $16 version) sit beautifully on our sunshelf, which is about 6 - 8 inches deep.
Reactions: MeowMeow724
