- Oct 1, 2021
- 1,434
- Plaster
- Pentair Intellichlor IC-60
The response was: You need a chemical check valve if it's within 3' because when the system is turning off it still produces a bit of chlorine and will leach backwards. But if you don't want us to install it we can remove $100 from the cost. Thoughts?You'll shave about $100 off with no check valve. Expect pushback
My setup will be within 3 feet. The guy seems receptive either way. I just don’t want any trouble in the future with any company insisting that was a flaw and why my warranty won’t be good. I’m good with some things but plumbing fixes are not my forte. I’m getting a replacement Mastertemp 250 at the same time.
