Las Vegas Build - It's like butter
daddymack
325
Las Vegas
That's more than enough. The biggest factor in determining runtime will be chlorine production from the swg once you install it.
Okay cool.. I also reduced the RPM to 1850 3x's a day and once 1x a day at full.. see how the flow goes... it was at full blast...lol I called it "Feature 8" for the lower speed.
bdavis466
Platinum Supporter
Aug 4, 2014
5,529
San Clemente, CA
The POOL circuit should be your lowest speed (that still allows the swg to operate) and then step it up from there for other functions. By doing this your day to day filtration and chlorination will be done at the lowest possible speed saving electricity. The swg will still operate during other scheduled circuits so long as the schedules overlap.
That really is a lot of runtime at very high speeds. For comparison, I run my pump 9 hrs a day at 1250 rpm and my pool is over double the volume of yours. I'd run it much less then that but that's what's needed for chlorine production and acid dosing from the acid pump.
daddymack
325
Las Vegas
This Morning tests:
FC 2
CC .5
TC 2.5
TA 180
PH 7.6
Temp 75
CSI .4
I am doing nothing... I think the chlorine is swinging because of our weather.. it was in the 90's - 100 one day, then 80's next.. 90's again, and now, all of a sudden its dropping to the 80's and it rained.. cloudy, etc..
daddymack
325
Las Vegas
I'm surprised you TA is staying at 180. Are you adding much water to the pool from evaporation?
it was .. funny you should say that... it dropped to 160 today... but our temps dropped substantially.. so maybe it was evaporation? or operator error in counting drops :pukel: It is entirely possibly I have been reporting it a bit high because it turns pink then usually two drops later it turns what I would consider red. I have experimented a bit, continuing drops and usually it will stop changing color at a couple drops past that.
the temp of the pool dropped substantially overnight. ANd we had a huge windstorm,... that.. you guessed it.. dropped a substantial amount of sand and leaves and such into the pool.. awesome time cleaning this morning.
This Morning tests:
FC 1
CC .5
TC 1.5
TA 160
PH 7.7
Temp 68
CSI .35
adding a bit of acid
bdavis466
Platinum Supporter
Aug 4, 2014
5,529
San Clemente, CA
If you aren't already doing it for the TA test, use10ml sample, 1 drop R-0007, 2-3 drops R-0008 and each drop off R-0009 =25ppm.
That will help save some reagents and will get you accurate enough. Once you drop your TA you can switch back to the standard test.
rsilecchia
1
Henderson, NV
Hi My name is Rob and I am building a pool to right now too. I nearing plaster and have a few questions. Like you, I have been trying to get some experienced assistance. As you are building your second pool, would you be open to taking a call. Sounds like you have experienced some lessons learned. If you would like to email me, I will PM you my email address. Thx, Rob
kimkats
47,371
Tallahassee, FL
Rob, If you start your own thread and ask your questions on the forum I am sure there is someone that will be able to answer you.
I will keep a look out for you.
:kim:
daddymack
325
Las Vegas
Sure
PM me your email :)
Wow. Great build. Enjoy!!
Thank you!
Last night's numbers and today's numbers are identical...
FC .5
CC .5
TC 1
TA 150
PH 7.6
Temp 68
CSI .26
I was getting low on pucks this morning, so I added two....
I can't believe that its already been 10 days...
I will post some more pics, as my decking is pretty much finished. I fell a bit short on the 3/4" tiles, so I may be ordering a bit more. And a bit long on the 1.5" pavers... so I am trying to think of something creative with the extra pavers..
No one can believe they do not get hot, until they walk on them.. really a unique and amazing looking stone.. once I seal them, it should really bring out some great detail.
grumpiebk
901
FL
Pool looks great! A couple of questions for you:
What size and depth did you adjust the shelf to?
Have you been in the pool? How do you like the 3.5' depth? A lot of mixed reviews on this site about that depth.
daddymack
325
Las Vegas
My Wet Deck ended up at about 7" I wanted 8, the law is no more than 11 total inches to step so it should have been 6" without a step in it. I could have put a step to make it deeper, but I like the look without a step. If I over fill a bit I get to my 8" anyway.. The wet deck chairs I want work in 5 - 11 inches, so I am happy!! I have not been in my pool, except on the shelf, but I can tell you that I think it will be perfect. My buddy went 3 - 5 - 3, but has little kids and has no problem with adults complaining. If someone wants deeper, it goes to 5..lol..
its 3.5 - 5 - 4. I can float in all of it.. So I am good.
grumpiebk
901
FL
Awesome. We are going 3.5 - 5 - 4 as well. 3 kids under 3 so I think we will love it, if nothing else, at least for the next few years.
daddymack
325
Las Vegas
A few pictures from today and comparison to drawing (Thanks Brian!) ... I am pretty much done with the stone work (pavers and matching 3/4" tile).. I have to order a bit more, as I ran a little short on tiles...
