- Jul 18, 2013
- 527
- Vinyl
- Jandy Truclear / Ei
did you figure out what the problem was? I have the same issue. My lid and the o-ring look fine. Does any one have a link on how take it appart? thxHas anyone had experience with the sight glass part of their salt cell leaking? What can be done?
Just to being up an old article, I have one that is also leaking from the glass. I'm thinking the whole unit has to be replaced. The O ring is fine and lubed but the water is leaking from the top. Rather than buy a new cell, is it possible to put a dummy block and switch to liquid chlorine?
yes they sell a winterizing cap. It's @ $50 on Amazon.
Hello there... I've followed this blog, trying to find an answer to my problem: my salt cell is cracked and leaks severely. Earlier comments indicated the cap is not replaceable. I've seen the one that sells for around $40-$50 dollars online, but no comment regarding the replacement aspect. Are you aware - is anyone? - of this cap being replaceable - or not?
The cell should be under pressure. What speed is the pump on?I realize the air is coming in through the salt cell!
Two weeks ago, my cell quit working with a "Check Cell" error. Scheduled the pool store tech to come out for a warranty call, since my cell is only 6 weeks old. But before he came, I realized the cell had air in it, so assuming the air was coming from somewhere else, I bled off the air through the filter, and it started working fine. I cancelled my warranty call. I've continued to notice air in the lines, which I've been bleeding off every day, or so and finally today, I realize the air is coming in through the salt cell! I can push down on the top and water squishes out. I quit looking at it when I got a little shock, which makes sense, since power is applied! Called the pool store, and scheduled a warranty call for next week.
