Intex filter won’t turn on.
Unplug it, remove the filter if it has a filter cartridge- if its a sand filter remove the pump basket & check to be sure nothing is lodged in there anywhere - like pine needles or foreign objects near the impeller- if it looks good replace cartridge or basket & lid & unscrew the little doohickey on the topof thelid a little Until water comes out to then retighten. Try to run it again. You may have had air in it . If this works great ?? if not u may have a dud
