Is it normal for a sand filter to expand upward when you turn it on? It shrinks down when I shut the system off. I never noticed this before today. It happened after I backwashed the filter.
I flipped the switch where my timer is to shut the entire system off to backwash my filter. When I turned the system back on is when I noticed the filter stretch upwards, kind of like it grew. Then when I shut it off for the day it shrunk back down.Be very careful. Sounds like you're building up pressure and can be deadly. Tell us more about what you turned off.
As it's been asked before, what is the filter pressure while on and does the needle sit on the pin when it off just to be sure the gauge is reading correctly.I flipped the switch where my timer is to shut the entire system off to backwash my filter. When I turned the system back on is when I noticed the filter stretch upwards, kind of like it grew. Then when I shut it off for the day it shrunk back down.
Pressure sits at 20 psi when on high, which is what the pressure was at startup. when I put the speed on low it sits at 3 psi. I don’t have a video and it’s dark out now. I will take a video tomorrowAll filters expand when pressurized, but it depends on how much.
What is the pressure going to on startup?
The pressure was the same before and after backwashing the filter, 20. I usually backwash my filter once a week but I haven’t done it in about 6 weeks.Do you remember the "20" as being the norm after a cleaning/backwashing, also what was the pressure prior to your backwashing.
The volume of the earth is about 2.861531×10^23 gallons.By the way, small world.
