- May 23, 2015
- 24,474
- Plaster
- Pentair Intellichlor IC-60
Ok so here is where I am now
Before drain:
After
Now, I still can't run/use my SWG because a prong broke off on temp sensor plug and although I bought all new parts pretty much as we redid it all yesterday. That is connected to controller & I can't replace that plug. I'm sure when I call Circupool tomorrow the answer will be buy a pretty much new system & well that isn't in the realm of doable especially with the price gouging on swcg's now. So we will see what happens tomorrow. Looks like I'm gonna be jugging until I can figure it out.
If you look at your numbers for CYA, SALT and CH, they all have different ratios (50%, 17.4%, & 8.7%). I would not expect the CH to change as much as the other because the fresh water you are adding in already has very high CH. but the salt and CYA should have changed roughly the same amount.
This tells me your pool water hasn’t been mixed enough. Fresh water floats on brackish water and can take a long to mix unless you run the pumps for a long time and brush a lot.
You might try testing again in a couple of days.
