Well Texas, that was fun wasn’t it? While there’s still some poor weather down south, things are looking up.
We’ve noticed over the last few days many of yinz down south aren’t used to what we up north call “Winter.” We’ve compiled a list of some very simple tips and tricks to help you out as the cold snap breaks and you get back to your regularly scheduled weather. This list is nowhere near a complete guide, but with some help we’ll get your pool back up and running in no time. If you do run into any issues we ask that you please start a new thread so we can give you some customized advice.
Above all we encourage you to take your time! There’s no need to go out there and rush things. As a fellow enthusiast I get it and am proud of your go get em spirit. But the hidden parts will take longer to thaw. Like that frozen feed pipe that looks ok and then sucks a hand grenade sized ice chunk through the pump. Please don’t rush things, go back inside and enjoy a bowl of Chili you made during the cold.
- Be extremely careful when walking around your deck
- Let’s be honest, you just saw your first actual winter weather. Fun isn’t it! It does get better!! That wet spot on the ground turns to ice when it’s cold outside, and that ice is slicker than snot. Be extremely careful when walking that you don’t end up on your rear because I promise, it hurts like heck!
- Keep a very close eye on little ones! Kids and puppy’s will be very interested in exploring. Keep every set of eyeballs you have on them as the deck is a very dangerous area right now.
- Be prepared for additional power outages
- Once things start to come back online there’s good odds you’ll see spotty service at first in addition to the possibility of cool weather. If your pump is already dry, it maybe a good idea to wait a few days to let everything catch back up before restarting. Rushing out and blasting that pump on high will only cause additional demand on the grid
- If you do restart, don’t rely on your SWG. With this cold water it’s not gonna work. Prepare to use some bleach
- DON’T force ANYTHING!!
- If it’s frozen, walk away. There’s no need to go dumping hot water onto a pipe simply to heat it up. The expansion and contraction is what tends to break stuff. If it’s stuck, don’t force it. In time it’ll warm up and odds say it’ll move on it’s own again. Forcing that valve to open will only cause it to break
- Don’t go smashing things with a hammer!
- Odds say your pool will have a layer of ice in it, it’s ok. There’s no need smashing up the ice, in fact it could make things worse. Liner pools can have their liner torn or smaller chunks of ice could get sucked into places you don’t want them. If it’s frozen, leave it alone!
- Careful when you reinsert the drain plugs
- Many people are going to be re-inserting the plugs for the first time ever. Take a few minutes and make sure they’re not cross-threaded. If you see any leaks, somethings not right.
- If the plugs were removed, take a second to lube them before inserting them back in
- It’ll be awhile before your pool turns green
- Algae has a very difficult time growing in cold water. Because of this odds say your pool won’t turn green overnight. Don’t rush to start things simply because you want to avoid algae
- If you do find yourself very low on chlorine, dump some liquid chlorine into the pool and brush the walls. By brushing it’ll mix the chlorine into the water without the need of a running pump
- If your pump isn’t priming, don’t stress out!
- If you were one who totally drained your system there’s a good chance the pump is going to need a TON of water to get it’s prime back. If it doesn’t catch a prime right off the bat, keep adding water. Odds say it’ll prime in time.
- Inspect everything for damage.
- This is a tip that I suggest all pool owners do at least yearly no matter the weather. Now that your system is off-line, what better time to peak at all the parts for tears, leaks, or any other general damage?
- While you’re at it, what better time to lube all the o-rings and gaskets? The system has taken a beating the last week or so, since you’re not going to go swimming, give things some maintenance.
- Be prepared for leaks
- While the likelihood of broken pipes is small, there is a chance. If you have any fears of a leak it’s in your best interest to preform a bucket test to see if all is well or if you have a dreaded leak.
- If you do happen to have a leak, take a look at this article on repairing pvc. There’s some good tips to help you out.
