Can't really tell how fine it adjusts to but I can't see a failure happening! Why don't you try it out and let us know how they work...lol!
Bama Rambler said:Looks like the only difference between the NV & NVA is the pretty red thumbwheel. I bet you get the NVA even though it's not listed.
bobodaclown said:Has anyone tried using a duck bill valve for the check valve. I have a chlorine injector pump on our well (iron bacteria). It allows the chlorine to get injected to the water supply but doesn't allow the water to flow back into the chlorine container. When the valve goes bad it will allow reverse flow. OOPS. But its a 5 minute fix. Info on duck bill valve:http://www.general-rubber.com/flex-valve/styles/4100.html
minmex said:Has anyone tried this valve for a chlorine dispensing version?
http://www.usplastic.com/catalog/item.aspx?itemid=23076
It just goes over the tubing. Seems like perhaps two of them in line might work?
Could you use a venturi with a bypass manifold on the return side?mas985 said:The particular design that I proposed in the first post is based on using the suction side of the pump. This allows the pump to siphon the acid or chlorine out the tank. This type of setup only works on the suction side of the pump.
