Hi All,
I recently bought a place that has an in-ground fiberglass spa that at the present is inoperable. The pump is an old-school Aqua-Flo bronze pump (from what I gather A-series). The attached motor is 1.5hp that I think was replaced at some point. It is not working. What kind of motor should I replace it with? Variable speed (is that worth it for a small spa)? It is connected to a pentair cartridge filter that I need to clean up as well as a mechanical timer that I hope to also upgrade to a wifi controlled timer. The gas heater is a Laars Lite 2 that I hope still works (and also get hooked up to wifi at some point).
But of course, the first order of business is to get the pump working to then assess everything else. My goal is to get this this thing up and running and to try to do as much of the repair work myself. I don't mind educating myself with any resources you may suggest; it seems like a fun project to get done in my spare time.
