Welcome to TFP.
What model number pump are we discussing?
Show us pictures of the pump and motor.
What speed does the pump slow to?
Sounds like the high speed is the pump priming and then it slows to a set speed.
That I dont know. The iAqualink shows "offline" even tho it's running
You need to get that working first.
What do the LEDs on the antenna show?
  • H0698700.PDF
Show us the setup screen in Aqualink. Also how are you turning it on? It sounds to me like it is not correctly in Aqualink.
What version is this? The newer versions you put in the pump address. Was there a screen for that? Try adding it to position 3 and 4 and see what happens.
I put it on 3 and it's not slowing down after 3 minutes like it used to do. THANK YOU! No errors either.
One question: How do I get rif of the air bubbles in the pump? also what is a good RPM for water fountain pump? (Now epump 3)
V 1.5 How Do I change it?
Sweet! Bubbles should disappear when the pump runs at high speed. If they are not, your pump lid is probably leaking a bit. Try to lubricate the oring on the lid. That is the most common leak point.
Pump speed is per your preference on the water feature.
