Equipment Overview:
1. Controller: Jandy iAquaLink 3.0 with firmware version 4.3.13-e.
2. Pump: Jandy Variable Speed Pump (VSP).
3. Salt Chlorinator: Jandy AquaPure.
4. Power Configuration:
• Pump powered directly from its breaker, bypassing relays.
• AquaPure connected through RS485 alongside the pump and AquaLink via AquaPure board.
5. RS485 Connections:
• Pump and AquaPure sharing the same RS485 terminal on main board
• RS485 devices currently detected: iAquaLink and Pump (AquaPure not appearing)
Issues and Observations:
1. Pump Issue:
• The pump initially displayed an RS485 error and was not detected or powered.
• Resolved by bypassing relays and connecting power directly from the breaker to the pump.
• Pump now appears in the RS485 device list and operates as expected.
2. AquaPure Offline:
• AquaPure is no longer detected in the RS485 device list since making changes to the pump wiring.
• It shares the RS485 connection with the pump and iAquaLink due to the lack of a spare RS485 terminal.
• I do not get a RS485 connection error as no power is going to the unit from the board
3. Firmware Challenges:
• The AquaLink firmware I think is outdated (4.3.13-e), I want to update it to see if it resolves my issue although I can't find a clear way to do so.
• The iAquaLink 3.0 app and interface does not show a “Firmware Update” button.
Steps Taken to Resolve the Issues:
1. Pump Setup:
• Configured the pump’s DIP switches correctly for RS485 communication.
• Bypassed relays to provide direct power to the pump. My old 2-speed pump was connected through these relays.
• Pump now communicates with iAquaLink.
2. AquaPure Troubleshooting:
• I Connected the relay powering the AquaPure board, but there was no change.
• Verified AquaPure RS485 wiring is correct
3. Firmware Update:
• Verified that the iAquaLink app does not provide a firmware update button.
Questions:
1. AquaPure RS485 Connection:
• Could the AquaPure require a dedicated RS485 connection instead of sharing with the pump?
2. Firmware Upgrade:
• How can I update the AquaLink firmware without a “Firmware Update” button in the app or interface?
3. Power Configuration:
• Does the AquaPure require additional power connections beyond its current relay setup?
Additional Context:
The AquaPure was functioning prior to configuring the pump, and both devices were sharing RS485 at that time (with the old pump). The pump’s operation required bypassing the relay, but this may have impacted AquaPure communication or power delivery.
I appreciate any advice or suggestions from others who have faced similar issues with Jandy equipment. Looking forward to your insights! See some additional photos.
1. Pump Issue:
1. Pump Setup:
3. Firmware Update:
Questions:
Additional Context:
