You better hide those quick...... pool equipment is a hot commodity I bet.
Its getting more exciting, isn't it?!
Wow Lehigh Valley! I use to live in Allentown... pretty impressive pool for up there. Is the pad going to be screened by a fence? If so I would move on. If you are constantly looking at it.. make them fix it. It's a couple hundred dollars of concrete in a very expensive construction project... if it really noticeable and won't be screened why would you want to keep looking at it?They poured the new pad and it’s crooked. By that I mean it is not perpendicular to the pool and house and comes out at an angle. I know this may not make sense but the best I way I can explain it is that it runs along side of our rectangular pool and is not perpendicular to that side. To me it seems like lack of attention to detail and poor workmanship. My OCD is having a hard time dealing with it. Is this a big deal or should I let it go?
It is going to be obscured by a boulder wall and landscaping so it's not something i will be looking at all the time. I couldn't help myself and asked the builder if they there was a reason it was installed on an angle rather than parallel with the pool. He said he will look at it. To me, it's just poor attention to detail and that is something I can't tolerate.Wow Lehigh Valley! I use to live in Allentown... pretty impressive pool for up there. Is the pad going to be screened by a fence? If so I would move on. If you are constantly looking at it.. make them fix it. It's a couple hundred dollars of concrete in a very expensive construction project... if it really noticeable and won't be screened why would you want to keep looking at it?
Nope. And they “fixed” it by cutting it and pouring a piece right up against it. I plan on asking what he will do when it cracks.looks like no rebar![]()
What is the trichlor thing you are referring to?I would not personally want the trichlor thing before my SWCG. The acidic stew coming out of it can do damage to the SWCG.
As long as you run the pump 24/7 anytime there is trichlor in it, you will be OK
I never even know I was getting it. Would I ever have a need for it since I have a SWCG?It is the container for chlorine pucks, if you use them. Or leave it empty and it gives you the option of using but I suspect a floating dispenser is just as easy and they can give you a refund for that thing.
Maddie![]()
