- May 3, 2014
- 58,309
- Fiberglass
- Pentair Intellichlor IC-40
As James says, it really depends on water flow. TFP uses the 25% statement as that covers nearly all situations. If your pump/filter system is not hampered by only a 3 psi increase, use more. But blindly following a mark on a gauge is not a good idea.That seem mighty soon. Why do y'all recommend so soon? I always heard a dirty filter clean better. Love to hear yalls reason
That is still too high. I would suggest you check your CYA and be sure you are maintaining your appropriate SLAM level FC.
