Help! cloudy pool
With that data I get -1.18.
If it is scale, it should be coming off. Have scraped some of it off and tested it with acid?
You are using the web version. I use the app. The web version assumes a level of salt. So your number is fine.
Sorry ---
Scrape some off. Put in a throw away plastic dish. Put a drop of acid on it. If it fizzes violently, it is calcium carbonate.
App is easier for me! Try it. Enter a full set of test results. Save them by touching the Check mark. Go to Overview. Touch a parameter. See how you can change the goal level to see what you need to add.
Muriatic acid. What you use in the pool to lower pH.
