- Oct 25, 2015
- 5,809
- Plaster
- CircuPool RJ-60 Plus
Rich,Got the same one over a year ago. Still running like a champ. Did you get the seals/etc. too?
Kim,What kind of surge protector do you have to that fancy pump?
Note that the electrical compartment is susceptible to water intrusion.
I'm not sure how the water gets in, but I suspect that it gets in at the top screw that holds the compartment cover on.
Maybe put a piece of waterproof tape over the screw to prevent water from getting to the screw.
Waterlogged V-Green 165 pump motor
I recently replaced my Hayward SP2610X15 1.5 HP motor with a V-Green 165 variable speed pump. The installation was pretty easy and I set a schedule and left it running. About three days later we had a hard rain and when I checked it a few days after that I discovered the the pump had tripped its...www.troublefreepool.com
Pump dead - water in electrics - Help!
I have learned everything on this wonderful forum since becoming a pool owner 2 years ago. Thank you. My pump died in the recent rains despite the GFCI breaker. Water in the electric section. The pump itself was dry under the cover and there was water only on opening the electric section...www.troublefreepool.com
Outstanding Hayward Customer Support (Canada) on MaxFlo Pump
Hi All, Just wanted to share with you the level of support I received from Hayward Canada. I'm not a shill for the Hayward - just a consumer that over the years has had mixed experiences with a variety of manufacturers, and I thought I'd share a positive one. I opened my pool this past weekend...www.troublefreepool.com
Thank Matt! Interesting, seems to imply I could put brushes on the top corners of the roof and that would blanket the house and pool equipment. The 10 tall palms surrounding the house would be on their own.Looks like these guys are the people to call to discuss lighting strike mitigation -
Rolling Sphere Method Lightning Protection Design in Florida
To help determine where air terminals or strike termination devices are required on a building, our lightning protection designers use the rolling sphere method.www.bondedlightning.com
1.21 Gigawatts!!? 1.21 Gigawatts!!? 1.21 Gigawatts!!!!?1.21 GIGAWATTS!!!
