Outside under the screw. You could probably do the same, take the screw to home depot and find a rubber washer thingy. I'll post a pic of it.
You could also use some silicone to seal it then take the whole thing and gently place it in the trash receptacle... replace with IntelliFlo = Very much worth it
I actually tried an HD antenna at my house and couldn't get one chanel... not even one. No scrambled Mexican car dealership chanel, no weird chanel I've never heard of, not a single one. Since my options were limited I had no choice - we mooch off my brother's youtube TV account?@RMcGirr83 thinks @bdavis466 would rather pay for local channels than explore the glory of OTA Digital HD.![]()
This pump would make sense for you because you don't have the TOP OF THE LINE AUTOMATION SYSTEM designed to work seamlessly with the Intelliflo like someone else I knowThis is a great thread for me since I will soon have to make the decision of upgrading my single speed 2hp Hayward pump. A plug and play $400 variable speed motor seems very appealing since I can easily control the speeds with relays from my DIY controller. If I go Intelliflo I will have to do some plumbing mods and program the RS-485 controls.
No post is forgotten with this guy aroundFluctuations of Reduced Quantum Gravity and Nose Dives
Here's an odd way to do a nose dive and then the dead-man's float - That's a ground squirrel and it's literally pointing vertically upwards with it's nose touching the plaster surface...I have never seen a critter go like that before. Oh well, it was scooped out and given a proper desert...www.troublefreepool.com
A warning to the squirrels who don't work hard enough.
Underperforming squirrels are at high risk for water intrusion "accidents". Just saying.
I’m going to replace my IntelliFlo with a squirrel-driven, cast-iron water pump that I found used online from a site that sells equipment from the old Fukushima nuclear reactor site. I’ve also ordered these fancy cattle prods that have both digital inputs as well as Bluetooth 1.0 controls. The shock level will determine the speed of the squirrels driving the flywheel.
I think it will be an awesome upgrade ....
Never cut the red wire...a couple zip ties will get that cleaned right upWow! It's getting deep in here. Back to real V-Green stuff...
Since it's a dry day so there's no way to dump water on the electronics (I even moved the hose way away and turned off the valve) I decided to play around with the controls. I still have the old Hayward Goldline controller for my solar bypass valve. So I spliced into the control wire that closes the bypass valve (black and red wires) then ran that signal to "Step 2" digital input and put the black on common. Before doing this I verified it was a 24vac signal. Worked like charm! Not pretty yet but it works great. Controller calls to close the solar bypass and V-Green motor speeds up to 3200 rpm. Cloud goes by and bypass opens then motor slows down to 1850... very cool!
So each time I take a new step forward I run into more questions. With controls they get geekier and geekier. I'd like to add another digital control signal from the Intellicenter to set to high speed when the gas heater is called for also. The question I have is this. Does anybody know if i can use two separate 24vac signals into the V-Green input terminal. Specifically, I'm wondering if it's OK to have separate common connections that originate from 2 different transformers? Both the Haward solar control and the Pentair Intellicenter are powered from the same power center. I know the best long term solution would be to do solar control from the Pentair Intellicenter and get rid of the Hayward and then there would only be one common to deal with but I'd just like to run with the Hayward a while longer if possible.
Chris
