- May 23, 2015
- 25,699
- Plaster
- Pentair Intellichlor IC-60
You might also consider adding a healthy dollop of dielectric grease on those electrical line connections and ground after you’ve tightened down the lug. Dielectric grease is a good way to prevent moisture from getting on those connections and causing corrosion. As for the digital connections, just keep everything tight and short with as little exposed metal as possible. If you can put an easily removable enclosure over the pump without obstructing airflow, then that will mitigate water intrusion a lot.
