Cold Water Operation.
The display will show the LO code. LO indicates the temperature of Pool is < 54ºF (12.2°C). Chlorine production is stopped.
From Page 39 of the Installation Manual:
Chlorine production is not permitted below 51°F (11°C); operating the chlorinator in cold water might result in over-chlorinated pool water.
If more chlorine is needed, activating the “Boost” mode will override this cold water feature allowing chlorine production for 24 hours of operation.
This applies to the Jandy AquaPure and the Nature2 FusionSoft as they are sister products.
An optional "Spool" Piece (sold separately) used to be available to replace the cell during winterizing or cell maintenance.
This piece has been discontinued and is no longer available.
In addition, the AquaPure threads are proprietary, and Jandy does not offer replacement proprietary unions (the "male" piece).
If removing the cell is desired so that water may circulate without the cell, specialized plumbing would need to be added during installation of the cell.
One method is an additional PVC union after each end of the cell.
This method would require the purchase of 4 unions.
2 for when the cell is installed and 1/2 of the other 2 unions (the "male" 1/2) for the creation of the bypass pipe.
When a FREEZE CONTROLLER is used on pump equipment and the chlorinator is run through the winter, turn the CHLORINE PRODUCTION down to 10 - 20%.
