Equipment-Hayward
1.85 THP Variable Speed Pump
OmniLogic automation
All installed spring 2020 by previous owner/ builder.
Under “Select device” I see:
MSP. HUA 00-4c-07-f4-a6 version R3.2.0
MP 01-47-07-f3-f8 version R 3.0.0
MSP id 85587 (not sure what this means)
Problem:
CommLoss 10-01-14-15-1d VSP
My pump is no longer working or connecting to the logic board. The screen on my pump is dark so I can’t even turn it on manually to run. The heater is also not working. Screen is dark indicating no power I assume. There is power to the OmniLogic board so I don’t “think” it’s a power issue?
I don’t know the configuration password under the wizard section since I am not the first owner and the previous is unreachable.
How this happened:
Omni controller lost connection to router so I turned off my system at the Omni logic box restarted it and now have this communication error and my pump will not work. Terrific. Now 2 problems.
What I have done:
Sat on hold with Hayward for 1hr 50min and then they disconnected me. Never even was able to talk to someone.
My pool cleaner is not tech savvy and everyone in town uses Pentair (I did not build or buy pool, bought home with an existing system). So I am at a loss.
I have reset all the breakers in case I tripped some switch. Nothing. The system just rebooted itself.
I would appreciate any suggestions!
thank you
Katie
Problem:
How this happened:
What I have done:
thank you
Katie
