We had our IG pool resurfaced in December and chemistry was balanced immediately after by our pool guy. I took over maintenance after a few weeks and was simply brushing, vacuuming, monitoring chlorine and pH levels until a couple of weeks ago.
We had zero CYA because of the new water, so I brought that up (it needs to be brought up more - test refill on order).
I added 121 fl. oz. of 6% bleach on 4/12, then today I added about 16 fl. oz. after testing (those results below). Also, pH seems to be drifting up fairly quickly, but I've been attributing that to the steady rain we've been getting and the fresh plaster. It tested at 7.7 on 4/12 and again today (also reflected below).
My question is: do I need to conduct a SLAM? With these results, the only reason it seems we should stay out of the water is the temperature...?
04-16-2019 @ 04:14 PM
Latest Test Result Summary:
FC: 2.5 (12 minutes ago)
CC: 0.0 (12 minutes ago)
pH: 7.7 (12 minutes ago)
TA: 80 (12 minutes ago)
CH: 275 (12 minutes ago)
CYA: 20 (13 days ago)
TEMPERATURE: 62° (12 minutes ago)
CSI: -0.12 (12 minutes ago)
Side note: since the TFP site was updated this winter I've struggled to find the SLAM process description. I'm sure it's somewhere in plain sight, but I cannot, for the ever livin' life of me, seem to find it. :-| Any help pointing me in that direction would be greatly appreciated, along with help on the above.
Cheers~~
Cheers~~
