- Aug 20, 2020
- 7,770
- Plaster
- CircuPool RJ-60
That’s good is able to get treatment. Praying for him to have a good outcome.He was admitted with pneumonia.
If you aren't comfortable going toe to toe with
That is what I thought when I read the above...............Naw... I got this.
sigh.........of course he was...........gurrrrrrrrr on the doc or whoever released him!!1He was admitted with pneumonia.
My step son brought this home kit over the day before we took him into the clinic. It was super simple even though the instructions were in spanish. I don't know where the other set of instructions were. We opened the case with clean hands, put 6 drops of something into the top hole inside the case and I swabbed him and shoved the swab in the hole under the other hole in the case and closed it (what you see pictured). We waited 15 minutes but he showed positive within 2 minutes. Here is the pic of it after 5 minutes.My son has worked from home since the advent of Covid. His employer has sent him a home test kit with 20 tests per month. He recently needed to come see us and he made sure to do the test daily while here. It even sends the results to be printed out and recorded someplace.
He will return here in 3 weeks and I'd kinda like to play with it and see how it worked (no time before). Anyone know anything about these kits?
Maddie![]()
It's Abbott's Binax Now. $14 for two from Walmart.com. We use them after travel and before family gatherings. Easy, inexpensive, and one more layer of protection. (We are all vaxxed and boosted.)My son has worked from home since the advent of Covid. His employer has sent him a home test kit with 20 tests per month. He recently needed to come see us and he made sure to do the test daily while here. It even sends the results to be printed out and recorded someplace.
Maddie![]()
They also have a monitored version from emed. They send a test report that you can use for travel. We used that for a recent cruise. $35 per test. It's the same exact test. You log in and do the test with the camera on, and the camera stays on the test for the 15 minutes it takes to get the results.It's Abbott's Binax Now. $14 for two from Walmart.com. We use them after travel and before family gatherings. Easy, inexpensive, and one more layer of protection. (We are all vaxxed and boosted.)
Keep the oxygen going as much as possible. Do your best get him to stay on it so he can avoid #2.Update on Jim is this...
He's been feisty and pulling his stuff off all day. When he gets his high flow oxygen off, his levels plummet to the 70 range. If he doesn't settle the alternative is #1 restraints or last resort, #2 ventilation.
That's where we are right now. He told me n his son that he's ready to come home. There is no way he can do that safely at this time. He is very sick right now. I don't think I can safely say that he is improving at this time. If anything, he's probably getting worse because he's plummeting into the mid to high 70s.
I'm praying for him. Praying for myself. Praying for his son. We're trying to stay optimistic but it's hard.
I am not allowed in the hospital to see him. He is in isolation until he can get his levels stabilized. His phone just rings because he is now restrained. He's combative and ripping his stuff off. They gave him ativan to hopefully calm him down.Can you talk to him by phone? Or maybe ask them if you can come and stand outside the window and yell at him...............tell him he HAS to behave or he will NOT be coming home!!! Behave means wear everything they put on/in him. Sometimes if they know the "rules" it helps.
I was wondering why they hadn’t already done the Ativan. I hope it settles him down a bit. Fingers crossedI am not allowed in the hospital to see him. He is in isolation until he can get his levels stabilized. His phone just rings because he is now restrained. He's combative and ripping his stuff off. They gave him ativan to hopefully calm him down.
