Anyone use a 2 1/2 coupler?
Bski224
128
Long island NY
My union broke and while trying to get it off pipe started to crack from my salt gen. What’s best corse to fix this? I was thinking curing pipe and using a 2.5 inch coupler.
You can also just replace one union and adjust the other side with 2 couplings.
Is this pipe cracked?
If yes, you might need to replace the T for the flow switch as well.
Cut out the flow switch T and the cell union and replace both.
Cut at the red line, install new union tailpiece at the green dot, install the new flow switch T at the blue dot and install another union tailpiece after the flow switch T.
Remember to install the Nut before gluing the tailpiece.
Just Out of curiosity why wouldn’t a 2.5 inch coupler work if I cut it right at the break and put the new Hayward union connector for the Tcell.
Cut the pipe right at the break just before the “T”. Install a coupler right at the cut before the “T” the put my union connector for the salt cell into the coupler.
