Good job! Now you just test the FC, PH, TA once a day and see what happens. Once you find things are evening out you can back off on the TA testing as it really should not move that much on a daily bases.
Kim
Kim
If you just added stabilizer before your 5/16 CYA test, then it might not have all been absorbed yet at the time. It was then shown on the next two tests. However, another likely reason is that the CYA test is fairly hard to read and could have been a false reading. A lot depends on the lighting at the time. I would assume that your CYA is 40, since it is the most consistent reading you have had. You are not adding CYA using baking soda.
Since you're in Las Vegas, having a little higher CYA could be a benefit since it can slow down daily FC consumption in your hot sunny climate. I had mine at 40 in Phoenix and was losing 4ppm of FC a day. I raised it to 50 and now down to 3ppm daily loss. If that increases, I will consider going up to 60. That is the highest I will go though.
