Thank you, I was told to check my pool for a leak due to the CYA being so low. I didn't realize that the TA and PH work together, I was always adding MA on a daily basis. The pool builder will be out tomorrow to start a leak test and he informed not to do anything to the pool. If there is not leak (which I hope there is not one) I will drain the pool this weekend. I am also a bit confused with the salt being at 1800, I think its from the the bleach and the MA,
. I will let you know what the out come is on the leak. Thanks for your help!!!
