why cant i seem to get this pump cover on?
dmurthy
9
milwaukee
the guys who opened the pool had to crank the cover off. I know it should be tight, but it shouldnt be this hard to tighten this cap. any suggestions? new O ring?
I see you have an orange mallet sitting there. I use a rubber mallet to GENTLY tap the ears to loosen the lid and then to snug it up. Being tight prevents air leaks.
You also should use Pool Lube - Further Reading on the lid O ring.
