Hi Dirk --
I have a similar setup with a Rebel cleaner. I have always found cleaners and hoses in the pool to be very annoying, so I just make it a practice of always taking it out before I swim. On my setup, out of my pump there is a 3-way valve, with one side going to floor drains, and the other to skimmer and cleaner, each of which has it's own shutoff valve. With cleaner in, floor drains are off, cleaner is wide open, and skimmer is always at about 70% closed. This works just fine, skimmer skims, and cleaner cleans, even with my pump at 80% where I usually keep it on cleaning cycle. Pump always runs 100% when swimming because we like our waterfalls, so with cleaner out, the 3-way goes to all open, and the cleaner valve gets turned off, so I'm skimming and pulling through floor drains. PB recommended against running the pump with the cleaner out and floor drains off, too much suction trying to go through the partially closed skimmer valve. It's kind of a pain doing it this way and I know it's bad for the cleaner, but it seems to work out okay. These are the pics I gave my wife so she knows what to do when I'm not home.
