Fresno, I'm curious- if you just found our website, how did you learn of "BBB" which is an archaic term for "bleach, borax, baking soda". We don't use that term anymore. We say "TFPC" method for Trouble Free Pool Care method.
More importantly, you say you've been fighting algae for years- how are you testing your water? Or are you just letting the pool store sell you stuff and it isn't helping?
We *can* help you! Foremost to our madness is that owners need to test their water with a full test kit. We need to know:
FC
CC
pH
TA
CH
CYA
And the FC test must go up to 50ppm as some algae ridden pools *will* need FC over the 5ppm most simple tests do.
You can see our approved test kits at :
TFTestkits.net
Holler back with any questions we can help you with.
Maddie
Hi and thanks again for the help. I use a standard test kit (5 dropper bottles) for my regular tests, and when i suspect something's wrong, i take a water sample in for a more thorough test for free at one of the pool supply companies.
Yesterday, i took a sample in and the results are:
FC: 0
CC: 0
pH: 7.0
TA: 110
CH: 200
CYA: 80
I told the pool guy about how badly my pool is covered in algae. He said (like everyone else I've heard) to brush, brush, brush. But he also said only brush while shocking the pool or you make it worse (which i heard for the first time). I figure this is how the pool got in the state that it's in right now.
Based on the low pH level, the pool guy recommended adding 3 lb of soda ash with the pump running to raise the pH. And he said I need to get the pH in balance before I do anything else because adding chlorine would just be wasted.
The day prior to this I had added chlorine and shock to the pool so I believed him, but when he told me this I called home and had a family member add a gallon of chlorine and a pound of shock just to get the process started and so there would be "some" chlorine available.
I bought some baking soda from Walmart to raise the pH level because I had read that you could use it and it was cheap. Apparently that information is incorrect because I've now added 12 lbs to no effect. It seems that sodium bicarbonate is not an effective replacement for sodium carbonate, so now I need to go back and buy the right stuff.
This morning my FC is still zero but my CC looks like 1. 5, and my pH still looks the same. I added the last of the sodium bicarbonate and a couple of pounds of shock and a gallon of chlorine, and I'm going to go get a bag of soda ash to add.
The man at the pool store did have a good suggestion. Maybe you can tell me if this is right or not.
His suggestion was that since my pool is so completely covered in Black algae it might be better to drain the pool and chlorine wash it.
He suggested these steps:
1. Drain the pool.
2. Fill a 5 gallon bucket with one gallon of chlorine and the rest water
3. Use a big brush to scrub the entire surface with this solution.
4. Refill the pool
It sounds like a good idea, but I think I would also pressure wash the sides before I refill the pool. That should help get rid of some of the loose plaster that is coming off in droves anyway.
What do you think?
