What does your pool paradise look like?
TexEdmond
623
Edmond, OK
Pentair Intellichlor IC-60
I like that floating target!
It's a bit of a Maguyvered solution. I made my regular old chipping target float by attaching an adhesive backed split pipe insulation foam noodle from Home Depot. I looped a rope thru the target and tied it to both sides of the base, then hooked the loop over a short length of pipe driven into the ground. The pipe serves as a pulley and depending on which end of the rope I pull, the target rotates that direction. That way the target stays right in the middle of the pool but I can go down to the shallow end and hit 30-40 footers by just rotating the target that way. The two clips are still accessible so it folds flat for storage.
Reactions: jark87
6XSBChamps
170
Longview, Tx
beautiful. the slope side where you have the mulch and bushes, do you do anything there to prevent the soil from washing away? I had to build up on both sides of my pool and have a steep slope similar to you. I built it up as much as I could and I have sod growing now but I worry about the soil washing away under the concrete
jeffchap
1,829
Edmond OK
What kind of tree is that to the left. Golden Larch or some type of Fir Tree? Your spot looks beautiful.
Thanks! It a deodar cedar and it is beautiful, but I don't recommend it near a pool. It has needles, as do several other trees and bushes around our pool and they are the bane of my existence.
They were installed by the prior homeowner. I am constantly skimming needles out of the pool, year round, and every time I clean my filter cartridges they are clogged with needles.
The next time I need new cartridges, I'm going to put in a sand filter instead. I've had one before and much prefer them.
jeffchap
1,829
Edmond OK
Nothing but the metal edging around the outside. But it's not really as steep as it appears in that pic. Here's a side view. There are a couple of large rocks in there too. The landscaper may have added those to help with erosion. I don't know -- we bought it like this.FB_IMG_1628537340185.jpg
Reactions: 6XSBChamps
Wolfepack88
395
NJ
Fiberglass
Jandy Aquapure 1400
First thing I thought of is falling needles. Looks nice but you would want if farther away. Why do prefer sand to cartridge, I haven't read that before?
bmoreswim
Platinum Supporter
7,103
Central MD
Hayward Aqua Rite (T-15)
Sounds like your pool is a good candidate for disposable hair nets in the skimmer. I have two very hairy, shedding dogs that swim regularly. Just cleaned the cartridges and there was almost no dog hair. I could have counted the pieces of hair that made it to the filter since April.
jeffchap
1,829
Edmond OK
Ease of maintenance. I can backwash a sand filter in a matter of minutes. Cleaning my cartridges (4) usually takes a hour or two and results in a backache. Consequently I don't do it as often as I should.
I've read that cartridges filter better than sand. But having used both, I honestly can't see any difference. The only drawback I see to sand is having to replenish the water and stabilizer lost by backwashing.
jeffchap
1,829
Edmond OK
I'm going to try that. I'm sure it will help. But I notice some needles always slip by now when I take the baskets out to empty them.
blazin
300
Franklin, MA
The hibiscus have really enjoyed this years weather. The secret is heatwave June 🥵, monsoon July 😥, heatwave August :swim:.
Reactions: Casey and DogDad
bmoreswim
Platinum Supporter
7,103
Central MD
They do look great! Ours are very reliable. We have Lord Baltimore and Lady Baltimore. They are the latest perrenials of any we have to break dormancy. Usually after May 1st here.
TexEdmond
623
Edmond, OK
Lineman- cool light show both inside and outside of the pool! I lived out west of Lubbock for awhile and have been thru that part of the universe more than a few times. It's mesmerizing driving in the dark because the red lights on the turbines would all blink on and off at the same time.
Reactions: Lineman7
