I’ve read on here how these weir doors are so important but my pool doesn’t have them. We bought this house 2 years ago and there weren’t any weir doors on the in-wall skimmers. Should all pools have them or do some not need them?
I def don’t think I have a floating basket ring. There are no holes or slots on the sides of the skimmer for a weir door to be installed so how does that work? I do have the SkimDoctor skimmer baskets which suck the water in much faster.Yes, some type. There are a few weird ones that have a floating basket ring that works as a weir, so look inside.
Yes. Pollen can make a real mess in a skimmer sock. But better there than in the filter. Socks are much easier to clean.
Think it through. Water seeks its own level.Yes! I totally agree. Taking apart the filter and cleaning the 4 cartridges is a real pain in the butt! So do you think that the weir doors will help circulate the surface water more and help with floating debris? I stuck my hand in deeper in to my skimmer wall and I do feel holes where the weir doors should go (I was looking at the outside skimmer wall and didn’t realize they go deeper in). I also found a model number for my skimmer so I went ahead and ordered the 2 doors. Hoping that helps because I can’t stand the Dang debris floating and when it doesn’t make it to the skimmer then it falls to the bottom and I have to vacuum more. It drives me crazy!
As the pump sucks water out of the skimmer well, pool water flows into the skimmer well through the throat to maintain the level. So far, so good?
If the cross section area of the skimmer throat is 3"X12", that's .25 sq ft. Let's say the skimmer is pulling a measly 100 gallons per minute. That's 13 cubic feet per minute. 13 cubic feet divided by ,25 square feet = 52 linear feet. That means the flow coming through the skimmer throat will have a velocity of 52 ft/minute to maintain the water level. Now reduce that opening to 1/2"X 12". That's 1/6 the area so to maintain the water level that water is moving six times as fast or 312 feet per minute. That's a pretty good clip - 3.5 miles per hour; enough to overcome slight breezes and currents and pull water into the opening. The weir is critical. The skimmer weir limits the flow coming in to maybe the top 1/2" of water. Less water above the weir means faster current. More water above the weir means sluggish flow. You've seen that with the flow doctor. Restrict the area and the velocity goes up. The problem with the flow doctor is it makes a narrow throat not a shallow one. You're interested in only the very top fraction of an inch for skimming.
