Is this plumbed correctly? Plumber still working so I wanna catch it now
My pool is nearly finished with plumbing and I went around looking at the valve setup and where all the pipes go so I'd have a good idea of how things will work. I noticed the valve on the outlet side of the filter has a 3-way valve that is set up to always direct water to the heater inlet. The filter outlet side can be closed. There is a return loop from the heater that goes to the SWCG or back to the valve on the filter outlet. This side of the valve can also be closed. The only side that is always open is the section running to the heater inlet.
Should the filter outlet be able to be shut off? Seems like a recipe for disaster if you shut it off and run the pump. Am I being dumb or do I need to have a talk with the plumber when he gets back from a parts run or wherever he is? Thanks for any help you can give!
