So I am basically one week into the bicarb startup. After running the robot a couple of times, I’m not getting much, if any dust coming off of the plaster when I brush it. Honestly, when brushing before using the robot, the dust was a brown color which makes me think I was actually just seeing normal Phoenix dust in the pool while brushing and it was getting stirred up, but not getting filtered out.
My question is, can I begin using the heater if I am not seeing any dust while brushing or should I wait another week or two? Obviously, it is a matter of my willingness to compromise my heater, but my thinking is it’s probably safe to run the heater if I’m not getting any plaster dust. The other part of the equation is that I’m still only around 0.2ppm of chlorine and likely a negligible amount of CYA. That makes the water not necessarily sanitary for swimming. Will the high pH (7.8) hurt the heater or is it basically safe to run the heater at this point? My back needs some therapy after moving around 27 of the 37 tons of gravel I had delivered.
