- Jun 1, 2019
- 40
- Vinyl
- Pentair Intellichlor IC-60
Hey! I am interested in putting a valve actuator on the valve for my water fountain so I can remotely turn it on and off. I have the IntelliCenter and it is connected to 2 pumps (main/Polaris), the Heater (through the Gas heater control), and an Intellichlor60.
1) Will I be able to plug an actuator into the IntelliCenter without getting/installing another "personality"?
2) Any suggestions on actuators (Jandy Valve)? It just needs the two positions. The handle itself only moves 90 degrees, but I'm not sure if I need a 90 degree actuator or 180? I guess I really don't understand how the actuators work with the existing valve
Picture for what the pipe/valve look like (I know it says main drain, but the valves are the same and this was the easiest to get to for the picture)
Hopefully this is enough information
