- Sep 5, 2020
- 392
- Plaster
- Jandy Aquapure 1400
So Folsom? Most of that water in that area is pretty low in CH. So adding some is good. I would go to 250 ppm CH for now and see how it stabilizes. Pool builder likely waiting as right now you are getting some from the plaster as your CSI is so negative. Not necessarily a good thing. CSI should be about 0.5 right now.
Did you upgrade to premium ? If not you need to delete the one log you can save in order to save a new one. Its $8 for the year if you haven't and we can see them too. Many times we can avert an issue by something you didn't spot, or reverse engineer why XYZ happened from your history. It's freaking $8 and worth every penny. Lol.
Also go into settings and allow sharing so we can see them.
Perfect. Pre TFP I went 6.5 years algae free keeping the test strip grape-lollipop purple. I had no clue how much chlorine it was, but I knew it was 'enough'. (Free and clear above min).Turned light purple so at least I know there is sanitizer in there ---
One thing is clear. Two things are not clear.
CLEAR: Stay off of Leslie's pages.
Unclear:
What is the degree baume/percentage on the muriatic?
Is you pool 22,000 as your account details state or is it 14,000 as your signature states?
In a 14K pool, using 31.45% Muriatic will reduce pH by .4. I would use that as your upper limit on acid additions. Always use pool math. Always reduce pH in .4 or less increments.
No. You are learning and need more wiggle room than landing at 3 at the end of the day. Land at 5.Sounds like a solid plan?
Anytime you wonder, ever, Overnight Chlorine Loss Test.I didn't think I'd need 1 gallon of chlorine a day tho! Maybe I have hidden alge from the PB Chem start up guy not taking care of my pool for 1 week straight and basically having 0 FC
This time of year the environment sheds like its one last hurrah. I'm currently getting pollen like dust on the pool floor. (And the patio. And the cars. And the everything)I also never realized how much gunk is in the air!
That can happen even when properly chlorinated. I dunno if the trapped water in the ear goes stagnant or what, but I've gotten it from the shower in the cold months.Also add my 10 year old son got his first ever ear infection...doctor called it swimmers ear.
In a couple weeks you need to jack your CYA level for the SWG and don't want to extend it because you had to slam first.
Dont come ask if you should, just do.
Instead, come tell us *why* you are doing an OCLT and we'll high five you and help pass the time waiting for the results.
1 gallon of 10% is 4.5 ppm for you. Whether it's a warm week in CA or the chlorine isn't perfectly 10%, a gallon a day is about right.
