Hi,
I have a SWG (Autopilot DIG 220), single speed water pump and Jandy Ti5000 Air source heat pump. The timer in the SWG turns on/off the pump as per wiring in manual. The heater turns on/off the water pump when heat is needed. All three can be on together, two (SWG and water pump), two (water pump and heat pump). The water pump is getting old and I want to change to VSP. VSPs that I have looked at have their own built in timers Any ideas how I can wire the three elements so that the same arrangements will remain? I am worried that separate timers for SWG and VSP could risk the SWG coming on without the pump If a power cut resets the pump clock. Hope I have not confused everyone!
