My Pool: 26k gallon outdoor SWG pool. 5 years old. Pebbletech
Problem - black algae on bottom at various places. IMHO not major, but the Mrs. thinks the sky is falling.
What I've done (unsuccessfully)
- Shock Calcium Hypo (double and triple dose)
- SLAM - this includes adjusting CYA and all the other stuff along with SLAM recipe.
- Scrubbed like heck before SLAM and shock. This is tougher with pebbletech because it's not a smooth surface that you can easily scrub even with a wire brush without totally destroying the surface.
- Raised FC levels to 3-5ppm by running SWG higher
- Added trichlor pucks in a floater
It's almost an annual battle and each year I try something new each year with the above tweaks all unsuccessfully. Well, I guess that's subjective because it's Not that bad which might suggest my actions did help, but I think I figured it out: trichlor (53%) granulates. I grabbed a handful and dropped it from the surface and watched it sink presumably dissolving some, but some granules able to make it to the bottom and lay directly on the algae. Pump off to allow it to settle but it seems to turn all the black into brown in a matter of hours. The brown I read is dead algae. I was hesitate to do this before because I didn't want the chlorite to bleach or discolor my pebbletech, but that 53% gave me a little confidence that it might be low enough not to be a problem. I tested a small section first overnight before I decided to continue this morning where I noticed how fast this works.
So here's the question: why? I've raised the FC high relative to CYA during slam. Did all the crazy amounts of shock. Nothing worked, but was this simi undissolved and scattered trichlor granules packed enough punch to knock it out in hours because of the concentration? Is the chlorine in the trichlor different than what comes out of a SWG?
