I have a STA-Rite Max-E-Therm 200 SR200NA that was newly installed in July 2021. The LED screen says the Pool temp at the top then says ERR AGS. From reading the book, I'm a bit confused as to this being something that needs to be fixed or not. It says one of the elements exceeded 140 degrees and that triggered the message. The fix is to turn it off then turn it back on. Since they have a 2 year warranty, I wanted to see if i'm reading this right and should just do the reset each time or if something needs to be replaced.
