I've been using a company to add a spillover spa to my pool but it seems that they are unable to finish the project so I'm looking for advice to see if I am able to finish it. I have some calls in to see if I can find someone else to do the work, but if I can't get someone to do the work I'm hoping I might be able to do it myself.
1. The biggest issue is the light conduit they put in is leaking from the sides. I also attempted to run a light through it and I think it isn't wide enough (unless I am doing something wrong - I am using a Jandy Nichless light and ran the cord through and then tried pushing it in, wouldn't go in at all). They came back and sprayed it with something that worked for about 5 mins and then water started spraying out (see below image).
And a view before they sprayed the extra stuff over it:
Here is what the inside looks like, the light conduit is at the very bottom left.
I am thinking I'll need to completely remove the current conduit and put a new one in, but please let me know your thoughts here. Also, it seems like the placement is very low, do that seem right for a light or should it be higher? If I were to completely replace it (or if there's a better option) what would I use to do that?
2. The other issue I'm having is with the jets. They are running off of my VS pump (no extra booster or anything) and some of them are not working. I am wondering if they plumbed it in incorrectly or if it's an issue with the jets - the jets closest to the center put out the most water, then on the left side the next 2 don't work at all and on the right side the next one has a bit less than the first and the last has less than the 2nd if that makes sense.
I'd really appreciate any help/suggestions on what to do! I'm pretty handy but have not done much work with PVC so I am not sure what parts etc I'd need to make sure this is done correctly and won't leak in the future.
Thanks!!
Thanks!!
