Spillover Mode Delay?
Jwpool
3
Dallas
I’m a new pool owner and first time posting. I have a question about the spillover mode setting on my pool/spa combo controlled by an RS6 aqualink system. When I turn on spillover mode the Jandy Actuator Valve turns while the pool pump is running. Is that an issue shouldn’t there be a delay to allow the valve to turn and turn the pump back on? Sorry for the newb question.
Thanks in advance.
Jeff
ajw22
23,821
Northern NJ
Pentair Intellichlor IC-60
Jeff, welcome to TFP.
I think that is normal operation. Although my pool is closed so I can't verify.
I don't see a problem with the return valve turning while the pump is running. Water moves from the pool returns to the spa returns during the valve movement.
@PoolGate what do you think?
Jimrahbe
20,890
Bedford, TX
Jeff,
I am not up on your specific automation, but most of them have a check box in the set up that enables the pump to be on or off when the valves turn. I suspect yours does also..
PoolGate
5,413
Damascus, MD
Jandy Aquapure 1400
A short delay will not cause any issues and as far as I know, there is not really a way to program in a delay to give the valve time to move.
Jwpool
3
Dallas
Thanks for the responses. I appreciate it. Yeah, I haven’t seen any way to delay the automation.
PoolGate
5,413
Damascus, MD
Jandy Aquapure 1400
In addition, there should never really be a time when there is no output path for the pump in your system. Some port somewhere should allow water to flow.
