Spa trouble
Jbek77
Active member
Jan 3, 2018
41
Spring/ texas
What’s up TFP,
I control my pool and spa using easy touch and ScreenLogic 2. When I turn my spa on one jet has water coming out but with little pressure. I have my spa set at 100 gpm. But when I look at my screen logic it only registers 55 gpm. When I turn on the blower for a minute and shut it off all the jets are working. I check the rpm again and now it’s reading 100 gpm. Which is what I have it set at. To sum up this mess. My spa does not work unless I turn the blower on first. Very strange. Any ideas?
Jbek77
Active member
Jan 3, 2018
41
Spring/ texas
Ok I have an update. When I turned the heater on the spa worked like it was supposed to. So does this mean I can’t run my spa jets unless the heater is on?
Jimrahbe
15,356
Bedford, TX
77,
Is this is a new set up that has never worked, or has it worked for years and just now went bad???
Please post another pic of your equipment pad with the system in the Spa mode, but more from the top so I can see the valve positions.
Show me this page from your ScreenLogic set up....
Jbek77
Active member
Jan 3, 2018
41
Spring/ texas
Jim,
Thanks for the response. I went out this morning. Turned on spa with the heater turned on. Did not work. Same problem. I just turned my pool on. GPM stay at 55. I have my pool set at 30GPM but still reads 55GPM. I turned on my pool high which is set at 90GPM but reading still at 55GPM
Jimrahbe
15,356
Bedford, TX
77,
If this were my pool I'd want to eliminate ScreenLogic as the problem...
I'd first go look at the pump and make sure it says " Display Not Active".. this just confirms that the com port on the main board is working..
Then, I'd use the main control panel with the little 3" display to change pump speeds and see if it works from there.
I suspect that one of your Screenlogic transceivers is intermittent or bad, but that is the point of troubleshooting.. To find what works and what does not..
Jimrahbe
15,356
Bedford, TX
My wild guess would be a part of a wheel bearing from a cleaner... :scratch:
If it was in the pump basket it did not come from the pump...
Jimrahbe
15,356
Bedford, TX
Speaking of cleaning, when was the last time you cleaned your filter, and what is the filter pressure when running at 100 GPM??
