- Nov 12, 2017
- 11,903
- Plaster
- Pentair Intellichlor IC-40
In addition and specific to Massachusetts, you need to have an outlet that is within 10ft of the pool.
Well ?????? Go on.
^^^^ What he said!
Not specific to Massachusetts.
NEC 680.22(A)(1) Required Receptacle Location. At least one 15A or 20A, 125V receptacle must be located not less than 6 ft and not more than 20 ft from the inside wall of a permanently installed pool. This receptacle must be located not more than 6½ ft above the floor, platform, or grade level serving the permanently installed pool.
Of course, and that's a consideration if he knows what he's running and where. I was suggesting empty conduit as a way of leaving options open for future needs, the ones he might not think of now, or might think he'll never want. Never say never, unless there's no conduit under the deck!You can save a bit by using direct burial cable and not need conduit.
For sure. That's a matter of understanding why that is and planning ahead for the need. Even 360° can be pushing it, depending on number and type of wires.Realize the challenge with conduit is that you need pull boxes for every 360° of bends.
100%! I've recommended strong, nylon twine to others for this. What is pull tape?If you go conduit, leave a pull tape in the conduit incase you want to pull more wires later on, and make sure the conduit is sized large enough for adding more wires.
Thanks for the explanation. Just checked mine and it's 9.5 ft. Woo-hoo. It looked alot closer in the pics. I'll bring itcloser to the house to raise it and be less of a trip hazzard. View attachment 403123
What exactly comes with the robots ? Say, the S200 and S600 (depending on availability). They have a 50 ft cord, but is there a power supply ? Does the power supply have a cord ? How long is that, if so ?
Lol. Yeah that's all going. I will only reuse the conduit and wires if they appear healthy when I get all up in there. If not I'll start new from scratch.That outlet cover sucks. Get a outdoor rated cover with cutouts that let you plug stuff in but close the cover shield. That way if it’s raining, you can safely plug stuff in.
Industrial strength shoe lace. It's flat but crazy strong.What is pull tape?
Ah, flat, as in: you lose less space in the conduit? I'll look for that the next time I have a need...Industrial strength shoe lace. It's flat but crazy strong.
It's much less prone to retain the curls after pulling it out. I have had regular pull string wrap itself around a wire so many times it becomes useless for future use. (When using multiple drags)Ah, flat, as in: you lose less space in the conduit? I'll look for that the next time I have a need
They are 'moved them to the backyard' size. That's the best size. The pool wall can be changed. The stairs don't come but once a year.Are they the right size??? THAT is all that counts right now!
The S200 and the M600 come with a 60 foot cord and the power supply has a 5 foot cord connected to it... If you buy or get the caddy the power supply sits on it so you can have about 62 to 64 feet of cord...Thanks for the explanation. Just checked mine and it's 9.5 ft. Woo-hoo. It looked alot closer in the pics. I'll bring itcloser to the house to raise it and be less of a trip hazzard.
Awsome THANKS. Once I get some of the dirt out of the way I will have to play with measurements to see where I need an outlet for the robot. If I use the short side of the pool it might be a hair short to get across the patio and cover the far side of the 40 ft rectangle If I use the long side of the pool for power I will have 40ft of slack on the patio.The S200 and the M600 come with a 60 foot cord and the power supply has a 5 foot cord connected to it... If
