I've just had a chlorine generator installed. I've had the skimmer crack and leak twice last year, so its being replaced. I now have leaks around the motor on an eight year old Pentair Superflow pump. Had all this not happened at this time, I'd fork out the replacement cost by having a new Pentair installed for me. Its hard and not a lot of options. I'm looking at a Black+Decker replacement with DIY installation.
The output side plumbing was just redone. In input side has not room left to cut out and replumb without cutting out the shutoff valve and going into a block wall. Nobody is too exited about this as the pool water line is above the pump and plumbing. The original Pentair unions were replaced after cracking in the last 3 months.
The reading I've done make it seems as if the B+D can be a direct replacement, without the need to replumb.
If its just a matter of screwing down the input and output with some Teflon tape and hooking up two electrical legs and a ground, I think I can handle it.
I'm looking for any input from somebody that has just directly swapped a Pentair with a B+D pump in case there are issues I'm taking into consideration to do this myself.
Thanks
Thanks
